Bathroom sink faucet part
talan1688
Nov 28, 2022
7
CA
Hello. My bathroom sink faucet is leaking and I would like to replace the hot ceramic disc stem cartridge (Sepco watermark 15) . I was able to remove the 2 connected parts (IMG_4132). About a couple years ago, I was able to separate the stem cartridge (IMG_4133) and unknown part (IMG_4134) on the cold side. I purchased Sepco watermark 15 stem cartridge and was able to replace the leaking cold one. Now, the hot side is leaking and want to do the same. However, the 2 connected parts on the hot side are too tight and difficult to remove. I tried using 2 locking wrenches and WD-40 but still stuck so I gave up.
So, I was thinking of just replacing the entire 2 connected parts on the hot side but do not know the part name and number. All I can see on the part (IMG_4134) is Sepco.with no other model number. Can someone tell me what this part (IMG_4134) is called so that I can try to replace it along with a separate stem cartridge. I understand this is an older model faucet so may be hard to find parts. So, I was also thinking of purchasing a new faucet set just to use replacement parts but noticed that many don't have the similar parts. The reason I want to avoid a whole new faucet is because I am able to install the 2 connected parts from the top of the sink as the part beneath the handle (IMG_4140) just screws tight instead of using special tools under the sink. Any suggestions would be appreciated. Thank you.
    1.1 MB
    1,008.7 KB
    366.2 KB
    490.1 KB
    1.1 MB
Clamp a big set of Vice grip pliers on the body of the valve under the lavatory and brace them against the wall to prevent the valve from spinning.
Now with the proper size wrench remove the stem counterclockwise.
Call the manufacturer for replacement parts.
Thanks for the suggestion. I tried using the vice grip pliers but still loosen it. So, I will have to look for replacement parts.
