Bathroom faucet adapter leak
mac44
Dec 10, 2015
5
I am using an adapter on a bathroom sink faucet to connect to a clothes washer supply line. I wrapped the threads with teflon going around about four times. The connection still leaks. Any ideas how to stop the adapter from leaking? The connection to the washer hose is fine.
should be a washer inbetween the adapter and the faucet.
if it is still there, if you tighten the adapter to tight you will
cut the washer
misshapen the washer
either way, it will leak, you should not need tape or dope on those threads
pipe threads get pipe dope
threads with o rings or gaskets rely on the o ring or gasket pipe dope not needed
  • Like
Reactions: SHR
