Daniel Galtieri
Our home has a basement bathroom that is not used very frequently (maybe a few times a week).
This past Sunday evening we found a large pool of water in our basement around what I now know to be a drain for our HVAC condenser unit to the sewage ejector pit/crock for the bathroom basement.
This is this drain hole I'm referring to
We purchased this home a few months ago. When we did our inspection, we checked that the sewage ejector pump was working, which it was, and we haven't had any issues until this past weekend. In trying to troubleshoot what caused the water I again checked to see if the ejector was working by running the water in the bathroom and waiting for it to go off, which it did.
Thinking it was working fine, I cleaned up the water and moved on to my next (now obvious silly) hypothesis that the drain pipe itself was clogged. I went through the process of "unclogging" it, and thinking that was the issue moved on believing everything was fine.
Unfortunately this morning I came downstairs to again find a pool of water in the same room around that same hole. Between Sunday and today the bathroom has maybe been used two or three times (shower was run briefly, and toilet flushed once or twice).
This time, when flushing the toilet (before entirely cleaning up the mess), I saw water actively backing up.
Digging in to what issues might affect an ejector pump, I tried running the pump directly by plugging the float switch (right term?) in to the outlet. Pump ran fine, crock emptied. OK great, it's the float switch, right? Not so fast..
Wanting to make sure that that is the issue, I've been running the water for almost an hour now and the pump has gone off several times and no water has backed up - everything seems to be working fine.
I have not opened up the crock and looked at the pump yet, mainly because I'm not sure what I should be looking for at this point since everything, from a functionality standpoint, seems to be fine.
The electrical aspect of the pump also seems fine. It's on its own circuit, with nothing else plugged in to the outlet. I have not checked the draw from the plug though.
I also know it's not a clog in the pipe from the drain hole in the floor to the crock, since I can pour water in to the drain hole and hear it emptying in the crock (they're in the same room).
TL;DR: Sewage ejector has failed twice (water backed up in to basement), but seems to be working fine at the moment.
Any input on what I should do next or what might be going on would be appreciated. Thanks.
Edit:
Here's a picture of the ejector system / piping that goes off when I either run the bathroom shower / flush toilet or put water down that drain hole:
https://imgur.com/a/X6Quri9
Edit:
