After hearing my toilet hiss for about a year I finally installed a new Fluidmaster Fill Valve and Flapper Repair Kit. This stopped the hissing sound but another sound soon started. First it was just a little humming sound in the pipes below the bathroom. The sound then became a fog horn and is now a fog horn along with large vibrations in the pipes below in the basement. It is so loud now that it actually hurts your ears if you stay in the bathroom after flushing. The sound starts the moment the toilet begins to refill itself, during the flush there is no sound. Plus if you turn on the sink while the toilet is filling up it increases the volume of the horn sound and vibrations from the pipes. You would think the pipes are about to fall out of the basement rafters the way they sound.
While inspecting the pipes downstairs I noticed a spout/overflow in the elbow of a pipe was dripping clean water in front of the hot water heater. I put a 5 gallon bucket under it and collected over 2 gallons in one night. After that night I messed with the silver valve on top of the hot water heater which caused about a minute of continuous clean water to spray out of the spout/overflow. After this release of water the dripping has almost totally stopped.
Any ideas on how I can fix this? It is becoming so bad my neighbor asked about the sounds he has been hearing from my house when outside.
In the pictures you can see what I am calling the spout/overflow in front of the hot water heater and the silver valve I released on the hot water heater. Sorry for the non technical descriptions in this post, I am not familiar with plumbing by any means.
Thank you for your time and help!
