For about three or four years now, we have had an almost constant water hammer problem. I have had three different plumbers out to the house, plus the contractor who remodeled our bathrooms.
The contractor installed a large arrestor by our water heater and I've installed water arrestors in the back of our Kenmore front loader washing machine. The lines have been bled multiple times and one plumber tried adjusting the water pressure.
None of these things worked on more than a temporary basis. And by temporary, I mean a few days at best, a couple hours at worst. The hammer always comes back. Now when I bleed the lines, it no longer goes away. And it now also happens when the COLD water is turned on and off.
The contractor ripped into the tile in our new bathrooms (where the hammer sounds the worst) to check all the pipes and found no loose pipes or anything else amiss.
The problem seems to stem from the Kenmore front loader. I hate to wash clothes because every single time, the constant on and off of the water saver feature causes the worst hammering of all (although we also get hammer simply by turning on the kitchen or bathroom sinks). We were told by the Sears technician that this is a common problem with front loading washers.
At one point, the contractor adjusted the flow in our showers and that seemed to make the water hammer disappear, but it also made showering next to impossible, because the flow was far too weak. And forget a tub bath, if that's your thing.
Anyway, I'm pulling my hair out over this problem. Short of demolishing our $2,000 washer and throwing it off a cliff, or taking showers at a trickle, or re-piping the entire house, can anyone think of ANYTHING else that might help us solve this?
As I said, I'm at my wit's end.
