robertbarnes
Should I put a water Arrestor on both the inlet and outlet of a water heater? it seems that just the cold feed line is making the noise and shaking but was unsure if I need to put one on each line.
Also the cold feed to the water heater has a ball valve to cut on/off water to the water heater, should the Arrestor be before or after the ball value?
