Both are s-trapped. If that's for a double vanity, it's all going to need to be re piped with a proper double sanitary tee connection and dual vent. I'm sure somebody can do you up a diagram
Thanks!!! Yes, its for a double lavatory, but underground rough has already been approved, so adding a new line and vent is complicated. Two different inspectors have rejected it for the traps, but allowed the single 3" vent and drain...
The 3" goes down through the floor tied to the sewer line, and goes up through the roof as a vent. With a clean out half way up through the wall. In the photos it would be the right part where the two 2" lines with the s traps are connected.
