I'm probably overthinking all this, but would love some advise. We had our electric water heater replaced (tank was leaking) in February 2023 with an AO Smith LTE-80. This is a light duty commercial water heater that came from the factory wired for 277V and includes 2 dual rated elements (6100W 277V - 4500W 240V). The plumber did a factory authorized conversion which consisted of moving 1 wire on the distribution block in the heater to convert that system to residential voltage of 240V. So the elements are running at 4500W 240V (and verified by the conversion sticker applied to the water heater). I also verified with a meter the incoming voltage to the upper thermostat is indeed 240V.
About 2 weeks ago the heater started making a hissing noise. I was able to determine its the lower element that makes the noise when its heating. I flushed/drained the tank and didn't notice any visible sediment coming out in the water when it was draining. Filled the tank and the hissing noise persists when the lower element is energized and heating. I called the plumber who installed it and he said "Oh, water heaters start making that noise after awhile. Don't worry about it"
I don't think it's "normal", so at this point I'm just going to replace the elements. But here's the issue: when I look up the replacement elements (AO Smith 100347979) the description states they are 6100W 277V and doesn't mention anything about them being dual rated like the originals. Obviously 6100W 277V won't work since the heater is running on 240V. I don't want to order these in the hopes they are dual rated like the ones currently installed. Am I ok with just ordering/buying standard 4500W 240V elements? Like these: https://www.supplyhouse.com/AO-Smit...d-Copper-Mid-Line-Screw-In-Element-240v-4500w
Again, maybe I'm overthinking all this and those 4500W 240V elements will be fine, but I don't want to screw anything up.
