Bird Doo Head
Hello To All!
We've been seeking a toilet for our home. We want the one that has the shortest length from back wall to front of bowl (Knee versus Radiator). We measured for a corner toilet only to find that the distance from bowl to vanity cabinet and to radiator don't allow me to reach in for cleaning.
Ideally, the device will be standard height, round front and ten inch rough in. Roughing in for 12" might not work because of the angle & height of the horizontal waste line below. The offset is too small for even 22-1/2's rolled. Maybe an offset flange would work, but I'd still have to move a hydronic line. So, ten inch seems to be the best bet.
The shortest front-to-wall ones we've found are:
American Standard Cadet 3 (270DB.001) at 26-1/4" to wall. Price: $222.00 (Big Box. Supply Houses I use for hydronics can't get it)
3" Flush Valve
2-1/8 Trapway
MaP 1,000
American Standard Reliant (3332.DB.101CR) at 25-7/8" to wall. Price: $179.00 (Big Box only)
2" Flush Valve
2" Trapway
MaP 600
Gerber Maxwell (GSE20100) at 25-3/4 to wall. Price: Unknown. Have not found it yet, nor bowl & tank separately
2" Flush Valve
1-3/4" Trapway
I think the MaP is 600 from the MaP search.
The supply houses can get American Standard Cadet Pro, but they are about $80.00 more. I can't figure out the specification differences versus Cadet 3 other than warranty length.
I have read good things about Gerber and complaints about American Standard. So, this is confusion.
I've read here good things about American Standard Cadet 3 FloWise (Thank You to Breplumb) but I don't know if FloWise is the same thing as the Cadet 3 that I'm looking at (FloWise isn't mentioned in the documentation)
To my untrained mind, the Cadet 3 seems to have an edge due to flush valve & trapway size, plus MaP score, however I don't know how important those numbers are in real life.
Since everyone here has far more knowledge & experience than I, which one would you recommend?
Do you have good/bad experience with any of these?
Also, most come in 1.6 gpf and 1.28. Is there a performance difference? (Cost of water means something as we pay over 1 cent per gallon here.)
Thanks for sharing your opinions, recommendations and experiences with these toilets.
Paul
3" Flush Valve
2-1/8 Trapway
MaP 1,000
2" Flush Valve
2" Trapway
MaP 600
2" Flush Valve
1-3/4" Trapway
Paul
