So i had to change to valve on the waterline for my toilet and i forgot to use the new compression fitting and nut that came with it so i just slid it on and tightened it down and at first it did leak a little bit so I tightened a little more and it has stopped.....Am I good if its still not leaking the next day or should I take it off and put the new ring on? Suggestions? Thanks!
