Thomas_Frank
Hello, I’m having an issue with air in my home water system that involves air getting into my lines, but it’s ONLY on one side of the house. I have a well and water softener.
I’ve run the furthest spigots from the well but the air seems to keep coming back. I’ve checked for leaks and have found none. The bathroom’s closest to the well don’t have the problem, it’s the other end of the home which includes a kitchen sink, water heater & laundry room. Also the outdoor faucets (4 total) have air in them also. My logic is since it’s only one side of the house I’ve ruled out the softener as well as the well itself (check valve etc) and the pump, which seems if it were one of those it would be the whole house, not just one end of it.
Since I don’t see a leak anywhere I’m looking for suggestions as to how air can be entering the system only at the one end of the house and what else should I check? Can a water heater draw in air somehow? A water spigot draw in air without leaking? Thanks in advance for your thoughts!
