Aerator Tank Shaking When Water Turns On
cbyer89
Oct 13, 2024
5
New Philadelphia, ohio
Replaced the pressure switch a couple days ago. The day after, anytime water runs, the pipes start shaking and gauge goes crazy. I've tried everything I could find on internet to troubleshoot. Please help. I have 2 little ones and it's been hard not using water last couple days.
  • VID_20241012_120901_025.mp4
    13.9 MB
    4.1 KB
Why are there two pressure switches? There should only be one at the pressure tank. They are most likely fighting each other causing the well pump to cycle on and off practically instantly which is terrible for the pump. Which he part did you replace? Do you have any pics of what was there before?
There is a pressure switch for the aerator tank and one for the well. The aerator tank has its own pressure tank beside it.
I have no experience with that setup, not sure why the aerator tank would need a separate pressure than what is provided by the pressure tank and switch. Was the new switch you installed the same pressure range (IE: 40-60 psi) as the old one? Hopefully @Valveman will see this and chime in.
Yes purchased the exact same one. And the well and aerator tank both have their own pressure tank.
Ah, winter wheat. Brings back memories of my days on the family farm in South Central Nebraska and the Electrogator systems we used to irrigate.
That is why I do it. Planted hundreds or thousands of acres as a kid. Now I only have 5 acres as a hobby and to feed a few animals. Still using my Granddads 1963 tractor and wheat drill. My granddaughter was riding with me. Doesn't get any better. :)
Update, the guy from the company that installed the aerator tank back in 2013, just came. Charged us about $1000, said the pressure tank to the aerator was water logged. Installed new tank and says that should fix it.
Sorry I didn't reply sooner as you could have solved the problem for $525 instead of the new tank Band-Aid for $1000. Cycling on and off between 40 and 60 is what caused the tank bladder to go bad to start with. A bad tank is a sign you are damaging the pump from all the cycling. You can still add a Cycle Stop Valve CSV1A for $224 to solve that problem. But you could have gotten the complete PK1A kit with a new tank for $525. The tank you have is not nearly large enough without having a Cycle Stop Valve. With a CSV added that tank is much larger than needed but will still work fine. Not only will the CSV solve the cycling problem and make everything last longer, but will deliver strong constant pressure to the house like you have never experienced before.
https://cyclestopvalves.com/collections/pump-control-valves/products/csv1a
https://cyclestopvalves.com/cart
