Our shower drain backed up at our rent house... snaking it down the tub didnt work.
i removed the tub overflow pipe from the P trap (it seemed to be just sitting in the p trap, because it pretty much just lifted out... not sure if that's normal):
and the cast iron P trap is backed up with water. This is a picture of the whole system... the toilet drains fine:
I was planning on cutting it out and replacing with a PVC p trap... but i think i was having a blonde moment... why not try to snake the clog out from down at the p trap... duh.
So... that's what im going to try to do now... crawl back under and see if i can unclog it that way.
Any thoughts on anything? I assume that the best thing to do would be to replace it with pvc... but if i can get it unclogged i may just do that for now. Im already gonna have to replace the tub drain/pipe assembly because it was leaking and old/broken (the crossbars broke off the drain, so i imagine its gonna be a pain to remove).
If i replaced the cast iron, i thought i would cut through the 2" cast iron pipe about 6" before it hits the big 4" drain, and use a fernco coupler to join a 2" PVC to it... would that be an appropriate method?
