I'm in the market for a new apartment in NYC, where having a washer/dryer in your apartment is highly desirable. Some of the apartments listed are in buildings that allow washer/dryer hookups, but I would like to know if it is possible to add a washer hookup, when the location is not directly adjacent to the plumbing riser.
I have attached a floor plan of such a scenario, where I would have to route hot and cold water lines and a drain pipe around a bathroom.
These apartment buildings all tend to have concrete slab floors, so you can't go underneath.
And yes, there will be a problem with venting the dryer; a condenser dryer is the only viable choice and I know they don't work very well.
If it's possible, any idea how much I might expect to pay a licensed plumber/contractor for this kind of work, including opening up and patching up the walls?
Thanks very much for your insight.
