yes...
take the unit out of the bathroom...find 2 walls slide the unit into the corner,,,draw a circle where the drain hole is...on the floor
move unit out of the way.
measure from the wall to the center.of the circle you drew..both drections
write the measurements on a sheet of paper...put paper in your pocket.
go to the bathroom.
find the shower drain pipe, reach in your pocket, take out the paper with the measurements..you wrote down on it.
unfold the paper
measure the pipe as it comes out of the floor.
look at your paper...is the measurement the same?
if not,,,,say DAMN!!!
then
move the pipe
NOW...you have a hole in the concrete.
after you move the drain..
put the dirt back
the pipe MUST be correct...you have NO PLAY
after you are done moving pipe
you need a bucket...and 50 lb sac of concrete
take a STYROFOAM coffee cup,,,place over drain pipe.
dump concrete in bucket,, mix with water
dump the whole bucket..on the floor under the shower pan
set the pan...stand on it...do a little dance... get down...boogie time
push the pan down...into the mud...level it.
let the crete set up.
after it sets up..hook the drain up
