Accidentally left water running slowly, water dripped down the sprout and outside the sink.
Satish Manohar
Feb 11, 2019
Houston
Accidentally left water running slowly, water dripped down the sprout and outside the sink. Caused flooded floors. Not sure if its an installation issue or model issue.
Any pointer will help.
Bathroom sink.
Not really sure if you can make out from the picture attached, but if you zoom in you could probably see water dripping on the countertop instead of falling in the sink.
    1.3 MB
In addition to the spout dripping water back, that water shouldn't be finding its way to the floor. Must be getting under the seal between the spout base and/or the handle base and the basin. So sounds like 2 problems need fixing.
Also, check the aerator and remove any calcium buildup. These fancy faucets have a tendency to wick water down the spout when hard water buildup forms.
Full disassembly and sealing with putty is of course the ultimate fix.
