Hello,
I plan to move my plumbing around my house to open up the ceiling height and do a bulkhead around the room's perimeter. I'm wondering if I can connect the shower, toilet and vanity drain lines as a branch the plumbing stack or if each fixture needs its own line to the plumbing stack?
I planned to replace the cast iron with PVC while the area was all open and do a continuous stream of ABS pipe around the wall so I could get my ceiling back. Would this follow code, or anything else I need to bare in mind if I'm doing this? If it's not allowed, can you please let me know why?
I've included a rough diagram of what I'm thinking;
The drain from the tub/shower goes into a 1-1/2 ABS pipe. My thinking would be to connect it to a branch that connects to a 3" ABS Pipe (when it reaches the toilet) and eventually connects to the vanity with a 1-1/2 line. Then connecting to the current 4" Cast Iron Plumbing Stack (which I plan to replace with a 4" ABS plumbing stack.
I also had one more question, what's the minimum size for a plumbing stack vent? I believe it's a 3" cast iron vent that's currently installed.
Thanks for your help!
Adam
Adam
