Ars Glonalin
Active Member
Hi all, I'm remodeling the shower plumbing for SWMBO.
She does not want tile work (or stone) or any changes to the bath / shower side.
Tearing out the wall opposite the valve side is fine.
I saw a very cool looking valve / trim that seems to meet all the needs.
I'm looking into a 3-outlet shower. Apparently, 2 or 3, even 4 (up to 6) can be driven at once by some valves.
That type seems to want 3/4" pipe for H & C inlets (supply). One I saw, which may not be on the market yet,
had independent flow + on/off controls in various models of 2, 3, 4 up to 6 outlets.
I want to plumb a handshower, showerhead and default to the tub spout.
One type promised up tp 8.5 gpm, single knob to regulate thermostatic temperature setting,
and on/offs for each outlet, with temperature setting retained.
It also claimed, though it was thermo/mechanical (vs 3x the price for electronic), that it could be set
so only one outlet is on at a time. Top it off with a finish-trim wallplate that will cover a standard 8" 3-handle valve-set.
This sounds perfect, if a little pricey
Kohler - Anthem. Is this one a gimmick, or solid hardware? (*5 to 9 week lead time)
Without a lot of additional work, I can't get a 3/4" supply to the valve, so my installation
would have to step up from 1/2" lines, and I would make the setting for only one outlet at a time.
Will this still work installed this way? Anyone know of other valves that match these reqs:
- at least 11 x 3" finish trim
- control 3 outlets, at least centralize diverters to one valve
- thermostatic control
- reliable
- warranty + parts available
- max tub spout below is centered and 4 1/2" oc
- reliable
