Id like to get as much flow as possible to my showerhead. I realize shower heads are limited for flow but the restrictor can usually be removed.
I'm going to use the Hansgrohe ibox system which has 3/4" fittings and plan on having a fixed head shower on the wall and a rain head show from the ceiling, either or both together will be able to be used.
The pipes running to the valve, from the valve to the shower head and the shower head pipe will all be 3/4 CPVC. However, I'm having a few problems finding a good shower head with a 3/4" fitting. If i were to use 3/4" up to the drop ear in the wall and then have a 1/2" shower pipe for both the fixed shower head and also the rain shower head, am i going to loose much flow ?
Appreciate any help and responses.
Si
Si
