I recently contacted a few of our professional plumbers about getting ready for winter, asking if they had any advice. As winter hits, it's important to stay on top of your plumbing maintenance. Here's some advice from the Pros.
If you have any winter advice to add to this thread please help us out!
One of the things I can think of is. If you have a crawl space with a pump in it. Make sure the crawl space is warm enough to keep the pump and plumbing from freezing. Either seal it up and heat it above 36° or buy a lot of heat tape and insulation.
Well an obvious one, if your hose Bibb isn't frost free, shut it off and drain it. If it is frost free make sure it grades to the outside. Other wise it could freeze and burst. If your leaving your cabin for the winter, drain the lines and blow them out with compressed air if you can, drain the HWT, and put plumbing antifreeze in the traps. Make sure your heat tape works, usually the heat tape has a light where it plugs in.
Most obvious things are to make sure your hoses are disconnected and crawl space and attic vent holes are closed or covered. Frozen water pipes lead to big money replacement issues if they burst. Thawing isn't cheap either. If you have a guest house, garage apt or pool house not being used shut off water supplies to fixtures either drain or blow out lines with air and drain toilet. Adding rv antifreeze to toilets and sink traps will ensure no frozen problems under the sink or in the toilet and the rv antifreeze is non toxic as well.
Keep your garage doors closed. Especially if there attached or under your home. If your using a wood stove or some other alternate source of heat and you have a hot water heating system run the hot water system periodically to prevent it from freezing.
John
