faucetfluster
I have a ~3500 square foot home with municipal plumbing which feeds through a pressure regulator.
For the last 10 years that I've lived here, there has been a very slight noticable shift in water pressure in the upstairs shower when a toilet gets flushed.
Recently, if a toilet gets flushed, the shower pressure drops to almost nothing, and won't come back quickly unless you stop and start it again.
I inspected for leaks in and around the house, and I haven't found any. I do have an in-ground pool in the back yard, and I have no idea how to tell if it's draining and filling, but that's the only thing I can think of.
I attached a pressure gauge to the outside pipe just past the pressure regulator, and it reads at slightly over 110 PSI. I went to the back yard and checked there, and the reading is the same. I've read that 80PSI is the max, but I'm wondering if the size of my home or the fact that I'm on a big hill with a two story house requires a higher pressure.
Also, in my office which is right next to the main water input, I can hear when people are showering or toilets are flushing. It's not a knocking or rattling, but just the noise of the water flowing through. Recently as well, the noise has gotten louder, and it seems like toilet flushes are taking longer to fill.
My wife tells me that the water bill was double normal last month, but she thinks that has to do with an accidental setting on the sprinkler timers (the gardener enabled watering twice a day instead of once).
Visual inspection of floors, ceilings, and walls around the interior show no signs of a leak thus far. If it matters, the water heater is ~10 years old, and about a month ago we had our drains snaked because of a clogging disaster that filled our bathtub with unmentionable waste.
What could possibly be happening?
