Who suspected just a few drops of water can also wash the toilet bowl "clean slippery" in a few minu
moitruongdealvn
Aug 8, 2018
Hồ Chí Minh, Việt Nam
No need for sophisticated tools, just a few drops of dishwashing liquid you can clear the toilet in a flash without wasting energy.
Normally, when cleaning the toilet, many people will think of the legendary plunger, but not all families have this tool available in the home. How would you do that? Will you go to the store to buy the appliance to stop the toilet? No need to hurry like this, you just need a few drops of water is enough to clear your toilet quickly.
It sounds a bit irrational, but the fact is that dishwashers are not just household detergents, they can also become a "savior" when the toilet is blocked. Thanks to the strong cleansing ability, the same lubricant characteristics of the dishwashing will help lubricate the pipeline and help the waste float down the septic tank easily.
viec-thong-tac-bon-cau-tro-nen-an-nhan-hon-vi-nhovai-giot-nuoc-rua-bat-2-1497830176-width600height600.jpg
Note before proceeding through the toilet steps:
- Only flush once because when the toilet has flushed out, you can not always flush out the obstacles, but it will increase the status quo.
- Open the ventilation window.
- Use gloves and medical masks when preparing the toilet to ensure hygiene.
Wear gloves before storing the toilet to ensure hygiene.
How to clean the toilet bowl with water:
Step 1: Drop a few drops of water directly into the stagnant toilet. Note, do not put the dishwasher too much because it will cause waste, just a few drops just enough.
Put a few drops of water in the toilet bowl.
Step 2: Pour half a bucket of hot water slowly into the toilet. The heat of water should be approximately equal to the temperature of your hot tea cup as boiling water will ruin the ceramic tile of the toilet. Then leave it for about 20 minutes.
Pour warm water into the toilet to increase the activity and use of the dishwasher.
Step 3: Press the drain valve in the toilet and you will see the results are unexpected. If the toilet is clogged, you need to repeat it a few more times.
viec-thong-tac-bon-cau-tro-nen-an-nhan-hon-vi-nhovai-giot-nuoc-rua-bat-5-1497830176-width600height533.jpg
The last simple step is to jerk up and wait for the toilet to come back.
If you do not have dishwashers, you can use shampoo or some soap instead, but using dishwashing liquid is the best way. However, absolutely do not use washing water, detergent because they will kill the biodegradable waste inside the septic tank.
what is washing water?
and ???
"The last simple step is to jerk up and wait for the toilet to come back."
Jerk WHAT? and where did it go?
What happened to " just a few drops of dishwashing liquid you can clear the toilet in a flash without wasting energy."
looks like a lot of energy and effort in pouring hot , but not to hot, water into toilet and if that doesn't work might have to try a few more times.
Thanks for the tip.
