jhqpzjg
Hello Folks,
I have a Burnham compact gas fired direct vent boiler, which provides space heat and hot domestic water via a sidearm water heater. There is water dripping at a relatively slow rate from the Watts 9D-M3 backflow preventer valve atmospheric vent. I've read that the seals can wear out in these, or crud can build up causing them to 'vent' or leak. I'd like to replace it, which seems relatively straightforward, given the union connections. There is a shut off valve before the back flow preventer, but not one after it...only a Watts S1156F pressure regulator. Will this pressure regulator 'check' any backflow from the boiler, so that I can replace the backflow preventer without losing water or introducing a significant amount of air into the system?
I've also read that flushing the system may be indicated when replacing these valves, to avoid the crud problem that may have created the leak in the first place. Is this necessary? This is a process that seems not quite as straight forward to me, which leads me to my next question...
When I hire someone to work on my boiler, who should I hire? I've dealt with a number of plumbers over the years that say they're happy to work on my boiler, but I wonder if they really know boilers. What questions should I ask when vetting someone to work on my boiler? Is there a certification that is industry or manufacturer based that is reasonable to use as a starting point?
The images are rotated 90 degrees, but for reference they serve the purpose.
Thanks for any insight,
Jason
Jason
