Apparently xirix edited his post, because now he is just asking about floor joists. The IPC code I listed above covers plumbing holes in joists and studs.Do you mean beam or floor joist? It appears you mentioned both.
Actually, that large of a hole in and engineered I-joist is acceptable, depending on its location in the run of the I-joist. In college, one of my structural professors asked us what the web of an I-beam was for. His answer was to keep the flanges apart. The same pretty much goes for engineered I-joists. The flanges, the dimensional lumber part of the I-joist, is where the strength is provided. The top is in compression, the bottom is in tension, except where they are cantilevered, and there is very little strength provided by the OBS part of the I-joist.Here's what I was talking about in new construction here in NC. These were taken in the same house, a 2021 build. The flexible ductwork snakes its way through engineered ceiling joists, and note that the hole cut pretty much spans the entire "web" (the OSB) part of the joist. These were in two areas of the same house, on the first floor, looking at the ceiling joists. Home on a slab, so all the HVAC is in the attic.
From what I've seen, in the structural framing of a home, very little thought is given to what comes next--i.e. the plumbing, the HVAC guys, etc. It would be nice if all the HVAC folks did a Manual J/Manual D on each home, and the plumbing was all done by licensed masters. However that never happens. The worker-bees come in and cut whatever the heck they need with little regard for either the structure (as shown with the large holes cut near the bearing points) or the next guy coming in behind him. Everyone at the "builder" seems to be too busy to properly check on the subs....is a huge problem...no holes are to be located near a bearing zone.
