You had two 40 gal water heaters right, poorly piped ? Both a Rheem ?
JG, I don't doubt that could be done but my very limited plumbing experience tells me that something will go wrong and I won't get the darn thing in until the tank has glugged dry - if then (my experience of problem frequency is no doubt due in large part to little experience and all of it on an old house). I think I will use the pump.You don't. I did mine two years ago. I taped it and doped it and spun it in,while it glugged. There it sits now, with a new full port ball valve.
Twowax, I am confused. Trying to visualize what you describe, I still can't see how a hole in the dip tube would prevent siphon. If the drain valve is open and air is let into the top of the tank, whether through hot water pipes or pressure relief valve, the water should siphon. Actually, it seems like the higher the hole is on the dip tube, the easier it should siphon. What am I missing?There’s a hole in the dip tube to prevent a water heater from siphoning more than a few inches down from the top.
Opening multiple faucets won’t help.
You bet. Unfortunately, that might be a few weeks. Leaving in a couple days for first vacation in 2 years and might not have time before then.Let us know how that works out.
