Tom the Elder
Finally got around to draining my new 29-gal Rheem gas water heater - now 16 months old (located on back porch). Turned it off last night. Today attached hose to drain valve, shut off cold water, opened drain valve, and opened shower hot valve. When I opened the shower valve I could hear air sucking in. Went back to the porch - no water coming from hose. Double checked drain valve was fully open and could feel the hose beyond the valve was warm to the touch. Considered a possible blockage in this old hose so blew into the end and could hear bubbles in the tank - but still now water coming out (end of hose about 2 ft below drain valve). Opened the cold water valve and water gushed from the tank - but when I shut it again the water stopped completely.
My house is 70 years old so I can't imagine there is any kind of backflow preventer in the system and I certainly did not install one in the 30 years I have been here (yep, first water tank flush in 30 years). I could open the pressure relief valve but I seem to recall those can fail easily if used much - and I hope to regularly flush this tank. My plan was to drain the tank and replace the drain valve with a full-port ball valve to make flushing more efficient but the damn tank won't drain! At this point the only other thing I can think of is to call in an exorcist. Anybody have a better idea?
