I installed 2 bathroom faucets. The connections for the hot and cold water supply on the faucet are female 1/2 inch NPT. I bought a threaded male coupler/nipple to attach the water supply lines. I use teflon thread when I installed them. They both have a very very slow leak on both faucets on the end where the nipple connects to the female NPT on the faucet body. They don't leak where the nipple connects to the water supply hose. Have I used the wrong fitting? What is the name of the fitting that should connect to the female NPT? The one I used was a straight brass male piece that is entirely threaded. It was not the fitting that has the sort of rounded end, (flare?).
Pardon my terms if there are not correct.
Here is the link to the diagram and tech specs of the faucet:
http://www.cifialusa.com/prod_techspecs/221.156.XXX.pdf
Thanks for your help!
