havasu, the additive was specifically for that mix and it was specified on the box for use in lieu of water. I used the exact amount of stuff that it said to use.
I tried to sand it before I read this. Even got out a friggin belt sander with a thing that catches the dust (can't find an orbital one). It tore the sandpaper but it at least smoothed the sharp edges on some of the higher pieces. I tried chiseling at the stuff and its hard as a rock. It feels all weird and lump under the feet and I don't want to mess with more stuff so I moved on to installing the underlayment. I plan to use it to help with a template for the linoleum.
With the underlayment I can still feel the lumps, but when I put my trashcan (which is about as wide as the toilet) down on top of the area where the toilet will go, it does not rock or move, so I'm hoping it will hold it steady enough.
My toilet has a special SanaGloss finish that is supposed to repel stains and make it so the toilet does not have to be cleaned as often, but it seems its either not as good as advertised, or the hard water just ruined it.
Oh, I forgot to mention that I used one of those drill attached mixers for the job and it still didn't mix the stuff bc the mix had gotten damp in its bag and started to clump. One of the curses of living in a high humidity area.
I can't remember if I mentioned that we were unable to use the space under water heater for storage.
There was a large hole in the floor leading right under the house that let critters get in-- like snakes. I know for sure that they got in because I found a copperhead that got in to the area and tried to come into the house through a hole the cats tore in the wall (which I had patched) but it got stuck on the duct tape and died.
I'm seriously thinking of doubling up on the underlayment (which is not all that thick) over the area that is bumpy and see if it helps get rid of the bumpy feeling.
Any thoughts on that? Good idea? Bad? Somewhere in between?
