plumbdumby
Mechanics shop in Southern California, must be to code. is it possible?
I want to add a sink to a room that only has a toilet. the sink will be wall hung with cold water only. The toilet drain is stacked underground ,4x3 cast iron closet bend goes back to a 3" sanitary tee and drops to a sweep and then runs horizontal. out of the top of that 3" cast iron san tee is a 2" galvanized vent that goes through the roof, I want to cut into that galvanized vent with a 2x 1 1/2 T and arm over 3', then turn out for my lavatory.
cut out a section of vent and use 2x 1 1/2" galvanized tee with sections of pipe on both 2" ends and no hub that into place, 3' (+/-) 1 1/2" arm over with a 1 1/2" galvanized 90 tuning out, with a nipple in that.
cut out section of vent and band in 2x 1 1/2" cast iron san tee, with 1 1/2" cast iron arm and a quarter bend turning out.
what would be ther proper way to do this if there is one. Thanks guys.
