I don't know the specs on my pump, but we are in Maine with a drilled well, probably around 200' with a submersible pump that probably puts out less than 5gmp. It is a residential set-up, but we also grow about 1.5 acres of vegetables which have some drip irrigation and some sprinkler units. The pump is likely at least 15 years old and it's been used pretty hard.
We run a set of sprinklers that uses about 5gpm total. They will run fine, but get a little weaker after 20 minutes, but still will run as long as we want to leave them on at that slightly weaker flowrate. The pressure at the tank will sit around 30psi the entire time they are running. However, after we run them for a couple of hours, the pressure will very slowly rise from 30... it could take an hour to reach 50 and shut the pump off with nothing running. We have not lost water yet. If I shut off all water inside and outside and shut off the pump breaker, the system does appear to hold its pressure, so I'm guessing no leak. If we never lose water, I'm guessing we're not running the well low/dry, but I don't know if that's an accurate assumption. I do think that the pressure gauge and switch are not clogged and are reading accurately because the switch does open when the pressure gets to +-50. I haven't checked the pressure tank air pressure with the tank empty, but I believe that would help if we were cycling a lot, not the opposite where the pump just keeps running and takes forever to get to 50.
Would love some insight if anybody has some thoughts to offer. Thanks
