cgollapu
Well pump discharge connection was corroded and leaking. The connector broke off soon after extracting the pump. I am having trouble removing the connector piece still on the pump. Since I did not install the well, I just want to be sure I am removing the right part. I would appreciate it if you could confirm that the black part in the picture below with the red arrow should be removed. I am putting a lot of force on it to unscrew but it is not budging. Any suggestions on how to remove it are appreciated.
Thanks
Thanks
