Onceaplumber
I'm wondering if anyone out there has any information regarding Wayne shallow well pumps. More specifically, will a pump head that had a 3/4 hp motor behind it bolt up, and function, with a 1/2 hp motor from another Wayne pump. Any of you cold climate pipe wrenchers probably know what I'm up to, and how I came to quest for knowledge. Every Winter and Spring I accumulate several pumps from people that had the misfortune of blending extreme cold, water, and plumbing fixtures. Sometimes the pump head is cracked. Other times they'd head is pushed away from the motor; which breaks the mounting ears on the motor flange. I would like to combine the good heads with the good motors. I am just too busy to experiment right now. So I'm reaching out to any other people that aren't part of the "throw it away world".
