andy867
So, with the help of a plumber from BullsEye Plumbing, I managed to remove a troublesome piece of pipe and get the Watts Instant Hot Water Recirculating Pump installed and running. I also insulated the Water Heater with the Heater Blanket found at Lowe's. The problem that I am running into is that I am still running into the initial problem of having to water for hot water (even though its supposed to be instant).
I have alternated between the Timer Mode in 15 minute increments (Every 15 minutes it runs; also tried the always on setting, but to no avail. Everything including the sensor valve is installed correctly per the manufacturer's specs (placing the sensor at the furthest sink from the water heater.
I have checked the hot water supply lines at the 3 sinks in my house (1065 sq ft) and NONE of them are even lukewarm to the touch. Takes almost 2 minutes to get even lukewarm water. Once the Hot water arrives, everything is dandy, but I paid almost $200 for something that was supposed to alleviate this nuisance, not just sit there and drain my wallet. Any suggestions would be greatly appreciated.
