New well pump...check. Jet pump.
New check valve...check
No leaks and water will run through house but pressure tank will not completely fill and pressure on pressure gauge on tank will not go above 20-22 psi and pump will not shut off. There is air pressure in pressure tank.
What do I check next? Do I dig up the well line to make sure it's not cracked? Thank you in advance for any help/insight you can give me.
