mattmouth182
I'm looking for advise with my Sterling water softener. It appears to use Clack WS1 parts.
My water softener has seemed to be losing effectiveness over the past few months. I started noticing odd behavior like foamy and gross tasting water some mornings and harder water than normal all the time.
After doing some reading, I thought that maybe my media had been fouled by iron. I have an iron filter before the softener, but not too long ago had an issue where the iron filter drain got plugged and the filter itself started under performing. I fixed that issue, but figured the higher iron for a few months might have dirtied my softener's resin.
So I decided to try some "Rust Out" in the brine tank. After a manual regen, I ran the tap into a bucket and noticed the water was REALLY dark brown and foamy. Now I knew that the backwash process should have drained everything from the regen process down the drain and not into the house water. But I figured that it might just be that the Rust Out freed up a lot of iron and it didn't backwash enough.
Since it was so nasty, I did another treatment of Rust Out and let it regen overnight. I got the same results. I decided to do a manual regen with just salt and see how it looked. Less brown, but still really foamy and definitely bad. I did a 4th regen overnight a results were about the same as the third but the water seemed to clear up after about 2min of running the tap compared to probably 5+min after the first regens.
Something is clearly mechanically wrong since I am getting such dirty water after the regen. I was thinking about buying a seal pack and piston kit, but I'm wondering why it's not softening? I Could see the seals causing the leak to the freshwater, but not the lack of softening.
I checked the drain during the brining and backwash steps. It's slow during brining, but looks to be flowing plenty during the backwash step. I removed the drain fitting and checked it to be sure, it was unrestricted.
The water level rises in the "brine fill" stage, and seems to correctly draw during the "draw/slow rinse" stage.
Not sure where to go from here? Does it make sense to continue to try to repair this thing or does it sound dead? I figured if I can get it to soften the water, then that's proof its working, and I just need to repair the seals? But why isn't it softening?
Raw water hardness is around 20-30 GPG, also contains a moderate amount of iron and tannins.
Thanks for any help!
