Stingray454
Today I tried to install a new Rheem 42,000 grain water softener. We had been having low water pressure inside the house but no issue with the hard water spigots outside. After I hooked everything up I put the manifold in bypass and turned the water back on. I had water flowing inside my house at this point. I then slowly transitioned the manifold to the water softener and the water inside stopped. When I put it back on bypass there was still no water. The only thing on the installation I messed up was that I didn't add water to the salt tank before turning it on. I even put the old manifold back on in bypass and still no water to the house. Finally I just connected the copper plumbing lines together with a flexible hose and got water back to my house.
Can anyone tell me what is going on here? are these manifolds one way only? I'm really confused how I could not get water to go through two different manifolds.
