steventheplumber
What is the best technique to raise the water pressure of a plumbing system via PEX tubing?
so your saying to start with a 3/4 from the basement? should I change it at some point to a 1/2 or 3/8 to increase volume?
<<<<<<<<NEVER>>>>>>>
use 3/8'' pex
you would be wise to pull 3/4 to everything.
steve, you can not change the pressure at a house, inless you instal a pump
if your psi at the meter is 50. it will be 50psi thru out the house.
no mater what size pipe you install.
volume.
the bigger the pipe, the more volume.
if you run a 1/2'' line to a sink and tub
if the sink is running, all is fine, plenty of water
when you turn on the tub. the sink will decrease in volume
by half. it will APPEAR you have lost pressure. but what you have lost is volume.
now,,,if you ran 3/4 to the sink and the tub..then turned them both on.
you will have full flow at both fixtures. because the 3/4 has enough volume
to run both fixtures.
you should never. run 1/2'' to 2 fixtures, only run 1/2'' to 1 fixture
see my illustration
