Hi guys!
I'm new to this forum and I've seen some similar threads, but I'm not sure they address the same issue. So here's the situation:
A few weeks ago, my very old well pump tank sprung a leak, and since it was a Saturday and I didn't want to spend the emergency repair charges, I decided to replace it myself. Although it was my first major plumbing job, it went well and I have nice water pressure. But I have this strange minor issue.
If I open the centrifugal filter flush, I can drain water than the pump can keep up. The pump kicks in at about 40 psi, but the pressure still drops slowly, since the pump isn't keeping up. However, at exactly 30psi, I can hear a "thud" or a "clunk" from the system, as if a valve opens or closes. The pressure gaguge immediately drops to zero, but water keeps flowing, but only with the pressure provided by the pump. If I close the filter dump valve, the pressure rises to about 30 in about a second.
The pump switch is 40/60psi and the tank bladder pressure is 35psi (a bit low, admittedly). I didn't install an additional check valve, but rely on the one that's on the pump. The pump is probably 20 years old (at least), but works OK. It fills the system from 40 to 60psi in about a minute.
What's going on here? It's really not an issue for everyday use, but I'm worried something more serious may be going on. I'm thinking it could be either a bad check valve that opens at low back pressures or my tank bladder pressure being to low.
Any ideas?
Any ideas?
