Hi folks,
Wanted to ask if anyone knew if a water-powered backup sump pump would do us any good if we have LARGE water flow in severe rain eventslike enough water that it requires a 1/2hp pump to keep up. I think I understand that water powered pumps have lower volume per minute capacities than electrics, so would it be useless to try to install a backup pump that is water-powered?
And a related question, the guys who installed our 1/3hp pump which proved to not be enough to clear the water, suggested that we just drop a second 1/2hp pump in the same small sump and hook it into the same 1 1/2 in discharge pipe, and that running the 1/3hp at a higher float level as a backup to the 1/2hp would provide a backup and some redundancy. I am instinctively concerned that two pumps slamming into the same 1 1/2 in line would not work efficiently and might actually undermine one another by causing back pressure against each pump's output.
What do you folks think? Many thanks.
