After receiving extremely high bill, I jumped into investigating what caused it. First, I checked for any visible leak or improper toiler bowl on my property. All seems to be working fine. Made sure no one was using the water in all 3 apartments and went to basement to check on water meter it was running water approx 0.9 gpm (gallons per minute). I was monitoring for approx 1 hour and it was varying 0.6-0.9 gpm even though no one was using water in entire house.
When I close the main valve from street BEFORE the meter, then meter goes back to zero. Open it back up, usage goes again to 0.9 gpm.
I also closed the main value supply to house AFTER the meter, and meter goes to zero. Once open, it goes back to 0.9 gpm.
It appears as meter is okay and there must be water being used after the meter. I do not see any visible water leaks and meter keeps running like this 24/7.
Any suggestions?
Any suggestions?
