Water Heater Tee Issue
islhopr
Mar 1, 2020
5
I had to run a TEE off the water heaters main line running from the water heater to supply a washer with hot water. The water heater is a small 30 gallon one, that sits on a shelf above the washer.
I used a 3/4 x 1/2 x 3/4 tee reduction tee. Hooked up to a 1/2, 3' braided line to run to washer. The line will not supply any water from water heater? all other hot water taps in the house work fine, just not the new one ? Any ideas >?
Check disconnect the braided hose at thecopp connection install another connection like that ,aim it into a bucket ,turn the water on and see what happens
Master Plumber ! ;-), guess I narrowed down my problem ;_0
