MrDreamers
My water heater is leaking from the bottom and all connections are dry even the drain bib and relief valve and line though the relief valve I tried letting water out by lifting the little lever tab but no water came out so I think it's a bad relief valve.
But if I replace the relief valve does that fix the leak or did it cause a structural damage and I need to buy a hole new water heater?
If someone can help me with this question it will be much appreciated.
Thanks in advance.
Thanks in advance.
