Daughter's house. Two years old on 50 gal gas AO Smith. End "button" shows red indicating needing replacement and dripping from there about four drops per minute. House pressure measures 90#. No pressure reducing valve. Previous heater did not have an expansion tank and there were no issues with the TPR valve. When it was being installed, the plumber told me that the TPRs are "different" now and expansion tanks are needed on all water heaters. I had a Smith installed in my house since with no tank and no issues. Was the plumber pumping sunshine?
Can I just shut off the supply and install a new expansion tank pre-charged at 40# or must I increase the pressure? Since there is no pressure reducing valve, can I remove the tank and install a 3/4" brass plug since the system was fine before ?
