I'm glad it's working? For now. But I am still curious about your system.1)
*If I install simple air release valve , on the *top of loop* (horizontal plumbing) available at out side window, when air gets sucked from downstairs (low pressure) and pulling along the water with it passing through loop, what are the chances air will be released from valve and breaking the air pressure
which would stop water being pulled along?
Not sure why this is working. But to break a siphon you have to let air in.
but at same time I would need water from upstairs (i.e main line ) so to fill tank again.*
5) The system is working guys ,its absolutely workingnow
It's very interesting to me. Most people around here are spoiled. If I turn off the water to a building to make repairs they come out like rats from a burning building complaining that they were not given 24 hr notice. Whaaa Whaaa Wha
[1] In your sketch you have A going into building below the window and to left. Then the line coming out of wall to the tank also label A to the right of the window just as I drew in my sketch. So It's not a straight shot through the wall. ARE Sinks and toilets on the system between A into outside wall and A out of inside wall. Is this a correct assumption. Do you have a water heater in this system as well?
[2] So If I understand, you have to manually fill your tank by opening a valve. If you leave valve open and walk away you may over fill tank. and then you have to close valves to tank once it is full. Then you use your tank water only when the main common roof tank is empty. When on reserve tank, original check valve on line outside window was to prevent water from drain down to unit below. You replaced it with a high loop, but it still siphoned down to unit below.
The vent you installed failed because the siphon does not start at the tank. The siphon actually starts at the bottom of the loop where it comes out of the wall. The tank will drain down to that point with out a siphon so the vent on the line near tank is useless. CAP IT! To break a siphon on the high loop requires an anti-siphon device on the top of the loop. Not sure why the air release valve is breaking the siphon for you. But if it fails try using a vacuum breaker. I will close when water come in from roof tank. It will open and let air in, breaking any siphon.
[3] Another observation I made is in regards to the check valve you installed on the outlet/bottom tank line.
Not sure of it's purpose. Your sketch shows direction of flow from tank. Was this valve always there or did you relocate it from line outside window. I'm thinking why have a check valve preventing water flow into tank when you have available common water. This is what I think . Please correct me if I am wrong. you manually fill tank when common water is available . then close both lines to tank when full. when no common water you open bottom line only. Tank flows into your system. If common water returns check valve prevents tank from refilling. So if your not aware of or present when common water returns you don't get flooded.
Sorry for rambling on but like I said, this simple system you have is interesting.
If I am wrong on my assumptions please tell me.
