Hi,
my apartment is at level 3.
Previously I have had Non return valve (check valve?) installed which restricted water going out from loft tank.The area I live at has hard water conditions which damages Non return valve frequently.
So I thought to have U tube from main line (High loop )
Ironically, physics principles dont allowing this to work and water from loft tank is getting drained to main line (siphoned?).
The piping inside is like seen in images,The plumber has installed vent pipe also, but it didn't worked out.
is there solution to this problem? I seek help from members in this forum
points to note,
1)I want to skip vent pipe manual switching on/off, as when I am out & water is available in main line it would come out of vent pipe (what is air release & vaccum insert valve? will it do?) what is optimum location of vent pipe & height & size ?
2) the input & output of loft tank is given to single point to have water circulated in my apartment, so that i can use loft tank/main line water in kitchen/toilets (etc)
points to note,
