tigreeirecelta
Hi,
I am building 14 toilets, one next and independant to the other, in two rows of seven, back to back; they are for a camping. The problem I have is with the distribution of the cold water flow. The building will receive water from a tank that will have a pressure pump; this pump has a max flow of 63 litres per minute (here is the pump: Kit Presión Einhell BG-WW 1038 N 1,3HP - Sodimac.com ) what I am looking for is a water flow of 5-6 litres in each valve if one valve is open, two, three etc, or if 10 are open at the same time. What is the cheapest and most efficient way of achieving this?? is it possible??
Thanks a million for your help.
