mderren
hey guys i'm new here and i need some help
behind my hot water heater is a small drain which essentially just seems to be a hole in the ground with three pipes leading to it
the pipe in question is small about a quarter inch in diameter and after following it up from the floor it seems to originate from the main line leading into the house, i discovered this by twisting a few valves to see what happens and the problem went away after i shut off the incoming valve
i'm trying to figure out if this is normal, or if it is not what i need to do to correct it?
i'm assuming that this incoming line goes nowhere except back to the main line for the house, since it has to be run thru the hot water heater?
