I have a Laundry room that backs the Garage. It rained hard over the weekend, and Sunday I noticed a leak running down the Garage footer. Long story short, I opened the wall up and only the bottom plate has water - No water damage to the drywall/insulation, so the Laundry box is not leaking.....I tried some different things, and it for sure is not leaking......
Which brings me to this - I pulled some of the neoprene off the warm water side where it comes through the concrete - Maybe an inch or so down.......I took a towel, dried out as much as I could, and came back around 15 mintues later to find it full of water again - The cold side is not doing this
I sprayed some expanding foam around the pipe to see if that may be a temporary fix to a possible bigger problem. It's at a slow trickle - I have water running out of my garage and draining out the driveway from this spot.
This is only a recent thing, though by looking at the rust on the nail plates, it may have happened prior to me living here. This spot was never originally sealed when the house was built in 03'. This is well water, and the pressure guage is telling me I don't have a leak.......
Thoughts?
Thoughts?
