karenmarie031
- Joined
- Apr 11, 2023
- Messages
- 12
- Reaction score
- 1
I have conduit around the water main that comes into my basement. The conduit extends about 2’ off of the laundry room floor. Recently the conduit has been filling with water and overflowing, causing water to drip down the outside of the conduit and going on my laundry room floor.
This previously happened in October after some massive rain storms and lasted for about 3 weeks. It started again a few weeks ago after we had several strong rain storms in one week. So the conduit wasn’t overflowing for months after the first instance of the problem.
My property slopes down from the road, and my house is approximately 60 feet from the road.
We have also had crazy temperature swings during the last few weeks (below freezing some days at night and really warm during the days).
Also, a humidity gauge says I often have 60 percent humidity in my basement. An old dehumidifier can bring that down by 10-15 percent after running for several hours. I don’t know if the dehumidifier is working as efficiently as it did when new.
A plumber that I contacted wanted to rip out the existing water line, jackhammer concrete in my basement, etc. It was going to be a substantial amount of money.
Other information:
I have taken a photo of my water meter and then took another photo several hours later. There isn’t any change in any of the reading or dials.
We haven’t had any problems with discolored water or low water pressure from our faucets. However, the pressure regulator is before the water meter, so the house water pressure might remain constant regardless of the cause of the water coming into my laundry room.
Although it hasn’t rained in days, the soil is still visibly wet in areas where storm water drained on the property. The storm water drains in my back yard, but soil in my front yard could still be wet from all of the storm runoff, although it doesn’t appear to be wet on the surface. I think it rained about 1-1/2 inches over two days. When you think about how much runoff that caused between the 60 feet downhill from the road to my house, the soil near my foundation could still be wet, although the surface soil doesn’t look wet. The soil is clay, so it doesn’t drain quickly.
We did put in French drains more than 10 years ago, but I have no idea if they are still working.
Do you have any ideas of how I can resolve this without paying thousands of dollars? Should I buy a better dehumidifier, use duct seal around the pipe in my laundry room, wait to see if it stops by itself, or try something else? As a temporary solution, I bought a siphon and connected several feet of extra tubing to one end of it. I inserted that in the conduit, started the siphoning process, and a steady stream of water is going into my laundry room drain. This happens 24/7. (That solution is working. It has been a continuous science experiment to find something to divert the water dripping down the conduit, since my laundry room floor is not sloped properly and the water doesn’t naturally go into the laundry room drain. It goes under a wall instead, which is why it had to be diverted.)
The siphon could divert the water inside my house indefinitely, but I don’t want to ignore it if there is a bigger problem that could cause foundation damage. The fact that a steady stream of water is being siphoned out of the conduit scares me.
The plumber I talked to said it could be a water main break which is why he recommend ripping everything out and starting over.
I assume if there was a water main break, the ground would be mushy in my yard somewhere, but it isn’t. Perhaps there could be a water main leak, but the conduit is collecting all of the water, which is causing the end of the conduit to overflow (when a siphon is not used).
What do you think? Is it likely a water main break, condensation, or groundwater?
If you think this is caused by the recent rainstorms, how do I prevent it from happening again? I can use duct seal (or whatever you recommend in my basement), but I don’t know where the other side of the conduit ends in my yard, so I don’t know how to address where water could be entering the conduit pipe.
I greatly appreciate you reading this and offering any advice that you think might resolve this issue.
Edited to fix typo.
Other information:
Edited to fix typo.
