When my clothes washing machine was draining the water from the tub into the drain pipe, the water immediately started overflowing onto the floor.
I tried to check for a clog using a drain snake, and the snake went down easily with no resistance to about a foot under the level of the floor where it suddenly stopped. I figured that that was probably where the building’s main line was—it is a unit in a condo building and the washing machine is on the bottom floor.
I tried pouring boiling water along with baking soda and white vinegar, to see if that would help. But when I tried draining the washing machine again, it immediately overflowed again.
I called management and they sent a plumber to snake the main line from outside the building because our building has had problems before from this line getting clogged.
But when I looked down into the drain pipe, I could see standing water about a foot down—the drain pipe is about three feet tall in my unit. I checked again with my drain snake for any clog, and there still was no resistance all the way down to a foot under the floor.
So I am confused as to what could be the problem. Any ideas would be greatly appreciated as I cannot afford a plumbing bill right now.
Thanks.
Thanks.
